I am trying to get 3 pieces of the swept surface joined.
If I trim the surface, I get the first part.
But have I to rebuild the swept surface 3 times to get the 3 parts ?
Tx for your reply.
Tx for your reply.
Hi Michel
The first thing I did was to do a surface offset at a distance of 0 this makes a copy of your lofted surface
I then edited your sketch 4, used the convert entities command to convert the spline from sketch 3 and joined the 2 splines using 2 lines
I then did a surface trim using sketch 4 as the trim tool and I used the keep selections option to trim away the ends of your lofted surface
This now leaves you with only the middle section of your original loft
I now used the trim surface command to cut away the center section of the surface offset surface that I had created. You are then left with your 3 separate surfaces
Have a look at the attached file
Paul
Hi Michel
Paul
