Hello everyone,
I have created a title page as my first view in Composer. However, when I publish to HTML, the first view is shown as a zoomed out view of the assembly I am working with. This is not a view that has been created anywhere, and my title page is only shown after the 'next' button is selected. Incidentally, if I click 'back' after I reach the title page it doesn't go to back to to the assembly, but rather to my last created view. Any help to understand what is going on is greatly appreciated.
Thanks.
Hi Trey, you can change this behaviour under File -> Properties -> Document Properties. Tick "View Mode". It will then display whatever your first view is when you publish to HTML.
If you want this to be the same for all documents you create from now on make the same settings under File-> Properties -> Default Document Properties.
Incidentally the view you were seeing is from the animation mode i believe.
thanks
Alan
