SolidWorks 2014 SP4.0 & EPDM SP4.0 + hotfix
Had this issue for a while (2012/2013). SolidWorks will crash when closing a document.
Not linked to any specific file. Especially repeatable if it's the LAST document.
I've done all the repairs/re-installs/driver checks.
Done some shot gunning/troubleshooting and determined that it's DEFINITELY linked to EPDM. More so when EPDM add-in is loaded in the Task Pane.
If I set under the EPDM Options to have the EPDM "blueberry" (extra tree pane) be BOTTOM FEATURE MANAGER TREE. Problem is almost non-existent.
There was some references to this in the Knowledge base (some file specific, some general). None of which have been linked to EPDM.
Anybody else seen this issue?
YES I have observed the same issue after I check-in part and drawing after which I want to close the window and suddenly it will crash.
this happens 60% of the time I check-in. My guess is this is happening because I bring the files from outside ePDM and than I replace this files which are already there in ePDM with new update files. I believe this is the reason for crashing.
