2 Replies Latest reply on Oct 17, 2014 11:03 AM by Steve Soeder
    Revision table column count?
    Steve Soeder
      Hi, is there a way to count the number of columns in a revision table?
      I'm using the following to get the column number, and I'm wondering if there is a way to check the total number of columns because I want to set the value to a negative number if there is no match so I can handle this scenario in a later part of the program.  Didn't see
      'REVTABLE - this is the revision table on the current sheet
      Private Property Get REVTABLE() As SldWorks.RevisionTableAnnotation
          Set REVTABLE = DOC.GetCurrentSheet.RevisionTable
      End Property
      'REVDESCCOL - this is a long value representing the column which holds the revision description
      Private Property Get RevDescCol() As Long
          Dim lngX As Long
              While UCase(REVTABLE.Text(1, lngX)) <> "DESCRIPTION"
                  lngX = lngX + 1
                      'HERE:  I want to set set lngx=-1 if we've reached the last column, and exit the while loop
              Wend
          RevDescCol = lngX
      End Property
