Hello all,
I try do delete a file in a static Folder via dispatch. The Filname ist always different, so i can´t specify the Name.
Unfortunately i am not able to do this. Is it not possible to use wildcards like %?
E.g. "\%.pdf"
Please help!
Thank you,
Mario
I use Dispatch to delete an existing PDF in our "released" folder before copying the new PDF of the same name. For some reason when copying a PDF from the Vault to a network folder it will not overwrite an existing file. Anyway here is the Dispatch script I use, maybe it can help you with ideas. I get the name of the file (%NameOfSelectedFile%) from the file I run the script on (i.e. approve). You can also parse the filename to remove the extension and add whatever extension you need.
