Macro to open all SolidWorks files in a location and delete configuration custom properties
Question asked by Scott Ashton on Oct 17, 2014
Latest reply on Mar 22, 2016 by Deepak Gupta
I would like to modify the macro I already have for deleting out configuration properties - I currently have to have the file open and and run the macro. Would it be possible to modify the macro so that whatever folder the macro is in, it would open any parts or assemblies, delete out configuration properties, rebuild, save and close?
My plan is to use this macro with the task scheduler to process multiple files at an off peak time. My current macro is below:-
Dim swCustPropMgr As SldWorks.CustomPropertyManager
    Set swModel = swApp.ActiveDoc
    Dim vConfs As Variant
    Dim i As Integer
    'ClearCustPrps ("")
    vConfs = swModel.GetConfigurationNames
    For i = 0 To UBound(vConfs)
        Debug.Print "Main: " & vConfs(i)
        If vConfs(i) <> "Custom" Then ClearCustPrps (vConfs(i))
    Next
Sub ClearCustPrps(conf As String)
    Dim j As Integer
    Set swCustPropMgr = swModel.Extension.CustomPropertyManager(conf)
    If Not swCustPropMgr Is Nothing Then
        swCustPropMgr.GetAll vPropNames, Empty, Empty
        If Not IsEmpty(vPropNames) Then
            For j = 0 To UBound(vPropNames)
                Debug.Print "ClearCustPrps: " & vPropNames(j)
                swCustPropMgr.Delete vPropNames(j)
            Next
  swModel.ShowNamedView2 "*Isometric", -1
  swModel.ViewZoomtofit2
  swModel.ForceRebuild3 False
  swModel.Save2 Silent
  MsgBox "The Configuration Properties Have Been Successfully Deleted, The Model Has Been Rebuilt and Saved"
Thanks in advance.
Scott
