I am Looking for a Macro that let me change the part number in an assembly and lets me read all the Dimensions?
Question asked by Gavin Crasto on Oct 17, 2014
This is the Current setup of my code, I need to be able read all dimensions of a part and change the part number, I was looking for an example of a macro that can do that:@
Dim xlApp As Excel.Application
Dim xlBook As Excel.Workbook
Dim xlSheet As Excel.Worksheet
Dim i As Integer
Dim j As Integer
Dim k As Integer
Private Sub UserForm_Initialize()
Set xlApp = CreateObject("Excel.Application")                       'Create Excel Application Object
Set xlBook = xlApp.Workbooks.Open("C:\Users\gcrasto\Downloads\Material.xlsx", , True)  'Opens Workbook in ReadOnly format
Set xlSheet = xlBook.Worksheets("Legend")                           'Specify Sheet for data to be pulled from
With xlSheet
    For i = 2 To 15                                     'Starts Loop at Row 2 and ends at Row 15 (Exception to be built in to ignore blank cells)
        If .Cells(i, 1).Value = "" Then                   'If the current cell in the loop is blank, exit the for loop
            Exit For                                     'Exits Loop
        Else
            ComboBox1.AddItem (.Cells(i, 1).Value)       'If the current cell in the loop is blank, exit the for loop
    Next i
End With
Private Sub ComboBox1_Change()  'Event to fire whenever combobox1 selected index is changed
    ComboBox2.Clear 'Clears the contents of combobox2 whenever combobox1 changes selection
    With xlSheet
        For j = 2 To 30
        If ComboBox1.Text = "RB" Or ComboBox1.Text = "RT" Or ComboBox1.Text = "RP" Or ComboBox1.Text = "FB" Or ComboBox1.Text = "FS" Or ComboBox1.Text = "FP" Or ComboBox1.Text = "FD" Or ComboBox1.Text = "ST" Or ComboBox1.Text = "SA" Or ComboBox1.Text = "SI" Or ComboBox1.Text = "SA" Or ComboBox1.Text = "SI" Or ComboBox1.Text = "SW" Or ComboBox1.Text = "SW" Or ComboBox1.Text = "SC" Or ComboBox1.Text = "WM" Or ComboBox1.Text = "TR" Then   'Round Bar
            ComboBox2.AddItem (.Cells(j, 5).Value)
        Else
            'do nothing
         Next j
      End With
Private Sub ComboBox2_Change()  'Event to fire whenever combobox1 selected index is changed
    With xlSheet
        For k = 2 To 31
            ComboBox3.AddItem (.Cells(k, 10).Value)
        Else
            'do nothing
         Next k
      End With
Private Sub ComboBox3_Change()
   With xlSheet
        For k = 2 To 63
            ComboBox4.AddItem (.Cells(k, 11).Value)
        Else
            'do nothing
         Next k
      End With
Private Sub ComboBox4_Change()
    With xlSheet
        For k = 2 To 7
            ComboBox5.AddItem (.Cells(k, 12).Value)
        Else
            'do nothing
         Next k
      End With
Private Sub CommandButton1_Click()
    Label3 = ComboBox1.Text & ComboBox2.Text & "-" & ComboBox3.Text & "x" & ComboBox4.Text & "x" & ComboBox5.Text
Private Sub CommandButton2_Click()
Dim swChildComp As SldWorks.Component2
Dim vChildComp As Variant
Dim boolstatus As Boolean
Dim a As Integer
Set swModel = swApp.ActiveDoc
Set swAssy = swModel
vChildComp = swAssy.GetComponents(False)
For a = 0 To UBound(vChildComp)
Set swChildComp = vChildComp(a)
boolstatus = swChildComp.Select3(True, Nothing)
Next a
' NEED CODE HERE
Private Sub CommandButton3_Click()
ComboBox1.ListIndex = -1
ComboBox2.ListIndex = -1
ComboBox3.ListIndex = -1
ComboBox4.ListIndex = -1
ComboBox5.ListIndex = -1
Label3 = ""
Private Sub UserForm_Terminate()    'This event is fired when the userform is closed
xlBook.Close (False)    'Closes the Excel Workbook and does not save changes
xlApp.Quit              'Closes the Excel Application from memory, otherwise each time you run the macro it will create another running process that is impossible to close! without killing it from the task manager or command prompt "tskill excel"
