Alex Aan
[bug] adding a driven dimension to parameter list does nothing
Discussion created by Alex Aan on Oct 15, 2014
Latest reply on Oct 20, 2014 by Jared Conway
Info:
In design study, when a new parameter with a global variable which is a driven dimension is added, no action is occurred. After 30 minutes I found out that driven dimensions can not be added to the parameter lists.
What should be fixed:
Solidworks should alert that driven dimensions can not be added as a parameter.
Reproduction of this bug:
In the following file try adding a new parameter with category = Global Variable and from the Reference select box, select height.
