I need help from those who have Solid 2013, and that it can to import parts from ToolBox.
Who that can help me with that I will show him exactly which part I need, order to that later he would send him to me by email.
Thanks helpers!
Thanks helpers!
What help you looking for? Has the file corrupted for you? Can you ask your VAR to get you the required file?
The problem is that my solid is student version, so I can not download entire sections from ToolBox.
So if you have an original Solid 2013, I can tell you exactly what part I'm looking for, and you're just extremely transfers it to your computer and sending me by email.
Can you help me with that?
Elia, I would be happy to send the file but not sure if you would be able to use that in Student version.
Do you've the installation files still available with you.
I'm sure that I can use the file, because I'm currently in the process of building a project, and I have parts that I brought not from my versions. And the truth is, I'm not so sure the version that I have called "student version", maybe it is not a full version.
First of all, thank you!
Follow According to this explanation:
Toolbox> DIN> Structural Members> Steel> IPN Beam.
This is the part. I need from you please that you set the size IPN260, and in column of the "Length" you set 7200mm. And that's it, the part is ready.
After all if everything is ok tell me and I'll send you my email.
Thank you very much again.
Sorry for missing it out, here is your file.
