11 Replies Latest reply on Oct 15, 2014 12:38 PM by Newell Voss
    referencing active document when saving out configurations as IGES
    Newell Voss
      I used the SW macro recorder to create a program that will save out 3 different configurations in an assembly to IGES format for programming. From what I can tell, the macro does what it should, except for referencing the open or current document. I tried to run the macro on another assembly with the same configurations and it worked, but it saved to the original file location that I used to record the macro. I assume this is a relatively easy fix, I just don't know the call out for the macro to reference the active or open file location. any help is greatly appreciated. Thanks!
        • Re: referencing active document when saving out configurations as IGES
          Deepak Gupta
          Post your macro here and someone will check it out. Use advanced editor to upload the file.
            Jesse Seger
            Try this
            Dim Part As ModelDoc2
            Dim boolstatus As Boolean
            Dim folder As String
            Dim path As String
            Dim name As String
            Dim fileName As String
            Dim configs As Variant
            Set Part = swApp.ActiveDoc
            Dim n1, n2 As Integer
            n1 = InStrRev(Part.GetPathName(), "\", -1, vbTextCompare)
            n2 = InStrRev(Part.GetPathName(), ".", -1, vbTextCompare)
            folder = Left(Part.GetPathName(), n1)
            name = Mid(Part.GetPathName(), n1 + 1, n2 - n1 - 1)
            Debug.Print folder
            Debug.Print name
            configs = Part.GetConfigurationNames()
            For Each config In configs
                boolstatus = Part.ShowConfiguration2(config)
                fileName = folder + name + config + ".IGS"
                Debug.Print fileName
                longstatus = Part.SaveAs3(fileName, 0, 0)
            Next
                Newell Voss
                Thanks Jesse!
                The code seems to work as intended. There is only one other question I have. Is there any way to reference a folder titled "OUT" for the save location? This is a sub-folder we create within the original job folder which is always labeled exactly the same as: (OUT). This separates our design files from programmer files. I'm sure I could just create a copy and open up the assembly from within the out folder before executing the macro, however it seems like a relatively easy step to add in. Let me know when you get a chance.
                Best regards,
                Newell
                    Jesse Seger
                    Updated code.
                    Dim path As String
                    Dim name As String
                    Debug.Print folder
                    Debug.Print name
                    On Error Resume Next
                    MkDir folder + "OUT\"
                    On Error GoTo 0
                        fileName = folder + "OUT\" + name + config + ".IGS"
                    Next
                        Newell Voss
                        Awesome. Everything works perfectly. I know I said that was my last question but I noticed an issue that I hadn't thought of previously. In order to properly import these files from native SW to IGES we have to tag them with a coordinate system. Since we re-use the same sub-assembly by performing a "pack&go" the coordinate system remains in the same place with the same display name each time. So my question is: is there a way to include the coordinate system in this code? Typically I have to go file>save as>(select IGES from format type)>then there is an "options" tab that appears. In the options tab at the bottom next to "output coordinate system:" there is a drop-down menu that is set automatically to "default" or none. The coordinate system I create appears in the drop-down as " Coordinate System1". Is this a possibility?
                        Thank you again for your patience and cooperation. It is very much appreciated!
                            Jesse Seger
                            Try this code.
                            Dim path As String
                            Dim name As String
                            Dim modExt As ModelDocExtension
                            Set modExt = Part.Extension
                            modExt.SetUserPreferenceString swUserPreferenceStringValue_e.swFileSaveAsCoordinateSystem, swUserPreferenceOption_e.swDetailingNoOptionSpecified, "Coordinate System1"
                            Debug.Print folder
                            Debug.Print name
                            On Error GoTo 0
                            Next
                                Newell Voss
                                The files convert and save to the proper location. However, the orientation upon import is incorrect. I checked the part assembly and on some of the configurations the coordinate system was suppressed. I unsuppressed it on all the configs, saved the updated assembly, and then ran the macro again but still had the same issue. Not sure if its a code error or the coordinate system isn't being included for other reasons. Any thoughts?
                                    Jesse Seger
                                    Check the SaveAs options after you run this macro to see if the correct coordinate system is selected.
                                        Newell Voss
                                        The first configuration I checked did actually display "coordinate system1" in the drop down window. Unfortunately, all the other configurations and an entire second assembly I ran it on all displayed --default-- in the drop down area.
                                            Jesse Seger
                                            Ahhhhh... This should fix it.  And make sure your coordinate system is name "Coordinate System1".  Otherwise it will not select it.
                                            Dim path As String
                                            Dim name As String
                                            Debug.Print folder
                                            Debug.Print name
                                            On Error GoTo 0
                                            Next
                                                Newell Voss
                                                It still seems to be having the same issue upon import. this isn't entirely a major issue as I could have our programmer tweak his code to flip the view to the proper orientation if it imports the same every time. Although, after going through each configuration and checking the save settings for each I found that of the 4 configs, the first 3 all show coordinate system1 in the drop down menu as they should. However, the last one still displays --default--. Any ideas on why that is?
