2 Replies Latest reply on Oct 14, 2014 6:37 AM by M. Z
    showing i's value instead of i itself
    M. Z
      Hi everyone, there is part of my current research that needs to rename the name of each reference I created from Planex to x. Since the problem is hard to explain, I need to post the macro first.
      here is the key part of the macro loop:
      i = 1
      Do While i <10
      boolstatus = Part.Extension.SelectByID2("front plane", "PLANE", 0, 0, 0, True, 0, Nothing, 0)
      Set RefPlane = Part.FeatureManager.InsertRefPlane(8, 1 * i, 0, 0, 0, 0)
      boolstatus = Part.SelectedFeatureProperties(0, 0, 0, 0, 0, 0, 0, 1, 0, "????")
      Part.ClearSelection2 True
      i = i + 1
      Loop
      i = 1
      As you could see, I am trying to create 9 reference planes with the macro(in the future there might be a thousand or more). However, the ???? should be the VALUE of i in each loop. But if I enter "i" simply, it will not work cause every plane will be renamed as "i" and the program will not accept this. So how could I express the real value of i in the ???? area?
      This is a problem extremely hard to google for a beginner like me, sorry if the problem is too easy.
        • Re: showing i's value instead of i itself
          Deepak Gupta
          Try these:
          i = 1
          Do While i < 10
          boolstatus = Part.Extension.SelectByID2("Plane" & i, "PLANE", 0, 0, 0, True, 0, Nothing, 0)
          boolstatus = Part.SelectedFeatureProperties(0, 0, 0, 0, 0, 0, 0, 1, 0, i)
          i = i + 1
          Loop
          i = 1
              M. Z
              Thank you very much, I have spent the last 5 hours finding the problem and it appeared the problem I found was not the real problem. I don't know what to say.
              Let me make a conclusion for other readers:
              1. vb doesn't need little features like those in C++ to infer variable value rather than variable. If you need to combine a word and the variable value, do as the correct answer("text"&i)
              2.After you do a reference plane, it appears that even you don't clear your selection, you still need to select it to do further work on it.
