0 Replies Latest reply on Oct 14, 2014 2:27 AM by Pranjal Jamsandekar
    How to create corner trim after using the create 3 point arc method?
    Pranjal Jamsandekar
      Could anybody help me about how should I trim this line.Also I am attaching the code for the same.
      Dim swSketchMgr As SldWorks.SketchManager
      Dim swSketchSeg As SldWorks.SketchSegment
      Dim swLine(3) As SldWorks.SketchLine
          Set swModel = swApp.ActiveDoc
          Set swSketchMgr = swModel.SketchManager
          'create plane and insert sketch
          swModel.Extension.SelectByID2 "TOP PLANE", "PLANE", 0, 0, 0, False, 0, Nothing, 0
          swSketchMgr.InsertSketch True
          'turn on direct addition to database
          swSketchMgr.AddToDB = True
          'create sketch profile
          Set swLine(0) = swSketchMgr.CreateLine(0.025, 0.05, 0, 0.025, -0.05, 0)
          Set swLine(1) = swSketchMgr.CreateLine(0.025, -0.05, 0, -0.025, -0.05, 0)
          Set swLine(2) = swSketchMgr.CreateLine(-0.025, -0.05, 0, -0.025, 0.05, 0)
          Set swLine(3) = swSketchMgr.CreateLine(-0.025, 0.05, 0, 0.025, 0.05, 0)
          'create arc
          Set swSketchSeg = swLine(2)
          swSketchSeg.Select False
          Set swSketchSeg = swLine(0)
          swSketchSeg.Select True
          Set swSketchSeg = swSketchMgr.Create3PointArc(-0.025, 0.03, 0, 0.025, 0.03, 0, 0, 0.05, 0)
          'create corner sketch trim
          swModel.SketchManager.SketchTrim 0, -0.025, 0.03, 0
          'turn off direct addition to database
          swSketchMgr.AddToDB = False
