Hi
Having a strange phenomenon when inserting a part in a part an positioning it with the "move" feature.
See also the This is what happens:
- Started a part "part2". leave it empty.
- Started a part 'DS' (driving sketch). In this part is a top plane sketch starting in the origin and going to a piont X. dims don't matter in this stage.
- Open part2 and insert part DS in it. enable the option 'locate part with move/copy feature"
- Position with the move feature in the inserted part DS. Translate: first choose the point X and the the origin of part2. Part DS move to the location where poiunt X and origin part2 are aligned.
- do a refresh.
- Now do a ctrl-Q : with every ctrl-Q the DS toggles between aligne origins and aligend with point X.
- ps: tried e few different settings in the system options >external ref feature. But no real change.
Is this a bug or what. Anyone noticed this? ... And has a solution.
Example to be found here: Share SW Forum
Noticed this after usig this MO in 50 parts...
Nico
Works fine for me on editing your files OR even creating new one.
I would suggest to report to your VAR in case you're able to reproduce this.
