4 Replies Latest reply on Oct 15, 2014 5:12 PM by Lyao Myao
    Get mate faces
    Lyao Myao
      Hello! I want to automate smart feature insertion by extracting faces for smart feature from mates data.
      I have part "box" (smart component) with face "box_face"  and part "block".
      They are mated coincident by box_face<->block_someFace.
      I want to run macro, to find face that mated with box_face and later apply smart feature to that face.
      Pseudo code:
      Dim targetFace as Face
      for i=1 to box.mates.count
           mateInfo=box.mates(i)
           if (mateInfo.face(1)='box_face') then 'if first face is our marker face
                targetFace=mateInfo.face(2); 'then we found it, store second face
           end if
      next i
      box.insertSmartFeature(targetFace)
      Now i m stuck at getting the face info from mates.
      ... got all smart part mates  in Mates array
      For Each SingleMate In Mates
            Dim swMate As SldWorks.Mate2
            Dim typeOfMate As Long
            If TypeOf SingleMate Is SldWorks.Mate2 Then
                  Set swMate = SingleMate
                   typeOfMate = swMate.Type
                   If typeOfMate = 0 Then
                              Debug.Print "Mate type: Coincident"
                              Dim mateEntityCount As Integer
                              Dim meI As Integer
                              Dim ents As SldWorks.MateEntity2
                              Dim zzzz As Variant
                              Dim zzzz2 As Variant
                              mateEntityCount = swMate.GetMateEntityCount
                              For meI = 0 To count - 1
                                  Set ents= swMate.MateEntity(meI)
                                  Set zzzz = ents.ReferenceComponent
                                  Set zzzz2 = ents.Reference
                                    'zzzz and zzzz2 will contain Component, not Face. How can i get faces for current swMate??
                             Next meI
      Next
      Thanks!
        • Re: Get mate faces
          Jesse Seger
          What does 'ents' contain?
              Lyao Myao
              help.solidworks.com/2015/English/api/sldworksapi/SolidWorks.Interop.sldworks~SolidWorks.Interop.sldworks.IMateEntity2.html
              The following tables list the members exposed by IMateEntity2.
              Public Properties [
              Property    EntityParams    Gets the parameters for this mate entity.
              Property    Reference    Gets the mate reference for this mate entity.
              Property    ReferenceComponent    Gets the reference component for this mate entity.
              Property    ReferenceType    Obsolete. Superseded by IMate2Entity::Reference2.
              Property    ReferenceType2    Gets the mate entity reference type for this mate entity.
              Public Methods [
              Method    GetEntityParamsSize    Gets the number of parameters for this mate entity.
              Method    IGetEntityParams    Gets the parameters of this mate entity.
              Reference and ReferenceComponent both return component.
              Params contain some(?) component point
                  Jesse Seger
                  This seems to work for me.  Notice the comments in the SelectMateEntity method.  Reference IS returning the face.
                  ' Preconditions:
                  ' 1. Open an assembly with a mate.
                  ' 2. Select a mate.
                  ' Postconditions: Selected assembly mate references are selected.
                  Option Explicit
                  Function SelectMateEntity(swApp As SldWorks.SldWorks, swModel As SldWorks.ModelDoc2, swMateEnt As SldWorks.MateEntity2, nMark As Long) As Boolean
                      Dim swEnt                   As SldWorks.Entity
                      Dim swSelMgr                As SldWorks.SelectionMgr
                      Dim swSelData               As SldWorks.SelectData
                      Dim bRet                    As Boolean
                      Select Case swMateEnt.ReferenceType
                          Case swMateEntity2ReferenceType_Point, swMateEntity2ReferenceType_Line, swMateEntity2ReferenceType_Circle, swMateEntity2ReferenceType_Plane, swMateEntity2ReferenceType_Cylinder, swMateEntity2ReferenceType_Sphere, swMateEntity2ReferenceType_Cone, swMateEntity2ReferenceType_SweptSurface
                              Set swSelData = swSelMgr.CreateSelectData
                              ' this is returning the correct face for the entity
                              Set swEnt = swMateEnt.Reference
                              swSelData.Mark = nMark
                              ' and this is selecting it
                              bRet = swEnt.Select4(True, swSelData)
                              SelectMateEntity = bRet
                              Exit Function
                          Case swMateEntity2ReferenceType_Set, swMateEntity2ReferenceType_MultipleSurface, swMateEntity2ReferenceType_GenSurface, swMateEntity2ReferenceType_Ellipse, swMateEntity2ReferenceType_GeneralCurve, swMateEntity2ReferenceType_UNKNOWN
                          Case Else
                      End Select
                      SelectMateEntity = False
                  End Function
                      Dim swApp                   As SldWorks.SldWorks
                      Dim swModel                 As SldWorks.ModelDoc2
                      Dim swAssy                  As SldWorks.AssemblyDoc
                      Dim swFeat                  As SldWorks.Feature
                      Dim swDispDim               As SldWorks.DisplayDimension
                      Dim swDim                   As SldWorks.Dimension
                      Dim sVarType                As String
                      Dim nVarFactor              As Double
                      Dim nMateDist               As Double
                      Dim nNumMateEnt             As Long
                      Dim swMateEnt()             As SldWorks.MateEntity2
                      Dim vMateEntPar             As Variant
                      Dim swComp                  As SldWorks.Component2
                      Dim nRetVal                 As Long
                      Dim i                       As Long
                      Dim bRet                    As Boolean
                      Dim vDimValueArr            As Variant
                      Set swModel = swApp.ActiveDoc
                      Set swAssy = swModel
                      Set swFeat = swSelMgr.GetSelectedObject6(1, -1)
                      Set swMate = swFeat.GetSpecificFeature2
                      Set swDispDim = swMate.DisplayDimension2(0)
                      Debug.Print "File = " & swModel.GetPathName
                      Debug.Print "  " & swFeat.Name
                      Debug.Print "    Type           = " & swMate.Type
                      Debug.Print "    Alignment      = " & swMate.Alignment
                      Debug.Print "    CanBeFlipped   = " & swMate.CanBeFlipped
                      nNumMateEnt = swMate.GetMateEntityCount
                      ReDim swMateEnt(nNumMateEnt)
                      For i = 0 To nNumMateEnt - 1
                          Set swMateEnt(i) = swMate.MateEntity(i)
                          Set swComp = swMateEnt(i).ReferenceComponent
                          vMateEntPar = swMateEnt(i).EntityParams
                          Debug.Print "      RefType(" & i & ")   = " & swMateEnt(i).ReferenceType
                          Debug.Print "        Component          = " & swComp.Name2 & " (" & swComp.ReferencedConfiguration & ") --> " & swComp.GetPathName
                          Debug.Print "        Point              = (" & vMateEntPar(0) * 1000# & ", " & vMateEntPar(1) * 1000# & ", " & vMateEntPar(2) * 1000# & ") mm"
                          Debug.Print "        Vector             = (" & vMateEntPar(3) & ", " & vMateEntPar(4) & ", " & vMateEntPar(5) & ")"
                          Debug.Print "        Radius 1           = " & vMateEntPar(6) * 1000# & " mm"
                          Debug.Print "        Radius 2           = " & vMateEntPar(7) * 1000# & " mm"
                      Next i
                      swModel.ClearSelection2 True
                          bRet = SelectMateEntity(swApp, swModel, swMateEnt(i), 1)
                      Next i
                      Lyao Myao
                      Thanks a lot! It works!
                      But now i'm stuck with the next step =)
                      i need to identify exact face, can i name part face somehow? via gui? some "face properties" dialog. Can't find it.
                      my part has few mates:
                      mates array {
                      entity1:  part_someface1 <=> otherPartFace1
                      entity2:  part_someface2 <=> otherPartFace2
                      entity3:  part_box_face <=> otherPartFace4 '<--------- here, named "box_face" face, so we can identify this
                      i have tried "SetEntityName" in part doc
                      and read using "GetEntityName" in assembly. But it returns empty strings. Looks like SetEntityName does not save information in file, just in macro memory.
                      code from here https://forum.solidworks.com/thread/67809
                      Found your message here https://forum.solidworks.com/thread/85961
                      it says EntityName is persistent between saves and on mating it automatically must assign EntityName.
                      Maybe i use wrong code to read EntityName for mateEntity?
                      Set mateEntity = swMate.mateEntity(meI)
                      Dim rComp As SldWorks.Component2
                      Dim planeFace As Object
                      Dim swEnt As SldWorks.MateReference
                      Set planeFace = mateEntity.Reference
                      Set rComp = mateEntity.ReferenceComponent
                      Debug.Print rComp.Name
                      Dim swRefPart As SldWorks.PartDoc
                      Set swRefPart = rComp.GetModelDoc2
                      Set planeFace = swRefPart.Extension.GetCorresponding(planeFace)
                      Debug.Print "name=" & swRefPart.GetEntityName(planeFace)
