I stupidly used a face instead of a plane when creating a mirrored part. The original part changed somewhat drastically, and now the mirrored part can no longer find the face. I can't seem to find a way to fix it. It wouldn't be an issue if the mirrored part hadn't already been checked into the pdm vault. Any suggestions on how to just point it to a plane to fix it, or do I need to create a new one?
SWx 2013
Jason
Jason,
If a plane exists that is in the right position for the Mirror feature, then I think you can just edit the feature and put that plane in the correct box. If such a plane doesn't exist, then you will have to make one at the proper position.
Jerry S.
