I am moving some legacy data over into a new PDM vault. I want the filename to populate a variable called part ID on the datacard as I add the files to the vault. How would I go about doing this?
Hi Matthew,
You can do this by modifying the datacard so the variable PartID uses the filename without the extension. (see image)
When you add files to the vault, it will use the filename. Keep in mind that it only does this on the initial adding of the file to the vault. If you change the filename you will need to manually change the datacard.
However, if you prefer to do it for specific files after adding to the vault, you can create a Dispatch action file that allows you to select the files, read the filename and fill out the variable on the datacard. (see video example) - to learn more about dispatch, google 'SOLIDWORKS World Presentations' and search on presenter name 'Garon'. (I put the link to presentation below)
SolidWorks World :: SOLIDWORKS World Presentations
Regards,
Joy
Hi Matthew,
Regards,
Joy
