I have a file data card that I converted to a search card. For this card, I use an input formula to change a variable, and use the result as a tab controller for the tab box. The reason for that is we are using the data card to create a formatted description and I need to break out the 'Type' of item into many different cards. However, I can group certain types together to lessen the amount of tabs. I am using the input formula against the type field and grouping for tab control. I need the 'type' to say the same for description purposes. My problem is that the input formula doesn't seem to trigger in a search card, or in the complete search, using the file card. I have tried using an alias list on type field, which kind or works as it switches tabs, but it also doesn't pull up results as the 'type' field doesn't match any values. I need the type field to be the original value and still trigger the tab control using grouped 'type'
Any ideas?
I don't think you can use Input Formulas on Search cards. You use it on the file data cards and then search it on the search card.
Check this
Re: 2012 EPDM Search Multiple Varibles
Not sure exactly what you are doing. But I've tried tabs Controlled by Variable - with Group as the control - and it only lets the user see one tab even if the user is in more than one group.
