1 Reply Latest reply on Oct 9, 2014 3:58 PM by Eric Irwin
    Trying to dimension a spline
    Scott Jenkins
      Not really trying to pick each radius or straight section more like an overall dimension in reference to length and width
        • Re: Trying to dimension a spline
          Eric Irwin
          So, what is the question?
          You can dimension regular splines by positioning their end points, then dimension the angle at each point (the arrow that you can drag around), and finally the curvature value at each point by the length of the arrow.
          For a style spline you can dimension all the lines/points of the control polygon and position the start and end points.
          The length of either type of spline can be dimensioned by just selecting the spline and then placing the dimension.
