Good morning all,
Have hopefully a simple question on suppressing features after making a new configuration. I have a structural tee which needs to be coped then have the resulting corner chamfered a certain distance in. I want to show on my drawing the part in original form before coping (see capture 3), then how it looks after coping (see capture 2). My default configuration has both "cut extrude" features unsuppressed to show how it looks after coping (cutting away of material). I then created a new manual top level configuration and made it current. I went to the FMT and suppressed the two cut features that show the tee's flange getting cut away then the resulting corner getting the 1/2x45 chamfer but then the part fails and I have a dangling sketch for the chamfer. Not sure why this is happening, I thought I was doing this properly. It should be simple enough. I've also attached my part file. Any help is appreciated. Thanks!
