MAPPING LAYER FROM DRAWING TO DWG
Question asked by Pascal Rajotte on Oct 8, 2014
I am using Custom Map Solidwords to DWG to export my drawing into dwg for laser cutting machine and can't do everything I want at the exception of engraving.
I do a scribe with the wrap feature on the unfolded part so that I can see it in flat pattern. But I can not find the layer on witch the scribe feature is on. On the save as file .dwg when I select the scribe line, it's on the phantom layer but when I try to map it, it's still on phantom layer ? Everything is  fine for the other layer to cut (geometry, hole... ) or grav (bend line...)
Somebody as ever try yo do this on is facing the same issues ?
