Hello SolidWorks,
I am reviewing over a thousand files (Part, Assembly, and Drawing) from a vendor that we outsourced a project. Our company has a list of custom properties [CP] that we use. Our Parts and Assemblies use one set of CPs and Drawings use a similar but different set. The outsource vendor also used their own in-house custom properties.
I am just knowledgeable enough to mesh parts of other people's macros and API to create what I need. I have no intelligible VB or API experience to truly make sense of things.
My issue is that I now have many CAD files with a hodgepodge of our company's and the vendor's CPs. It would be unbelievably time consuming to sort through all of them manually. I found a macro that successfully sorts CPs alphabetically; but I am in need one that sorts the CPs in a specific order and ignores or leaves the rest alone (to be reviewed for pertinent info before being manually deleted).
Is there a way to edit this alphabetically sorting CP macro to attain my goal? Any and all help would be greatly appreciated! I thank you in advance for your time and effort!
Dim swCustPropMgr As SldWorks.CustomPropertyManager
Dim vCustPropNames As Variant
Dim vCustPropVals As Variant
Dim Current As New Collection
Dim Final As New Collection
Dim i As Integer
Dim blnFound As Boolean
Set swModel = swApp.ActiveDoc
Set swCustPropMgr = swModel.Extension.CustomPropertyManager(Empty)
swCustPropMgr.GetAll vCustPropNames, Empty, vCustPropVals
'Put custom properties in a collection
For i = 0 To UBound(vCustPropNames)
Current.Add vCustPropNames(i)
Current.Add vCustPropVals(i)
Next i
'Insertion sort
Set Final = Nothing
Do While Current.Count <> 0
'First cust prop
If Final.Count = 0 Then
Final.Add Current.Item(1)
Final.Add Current.Item(2)
Current.Remove 1
Current.Remove 1
'Find place in Final collection
blnFound = False
For i = 1 To Final.Count Step 2
If UCase(Current.Item(1)) < UCase(Final.Item(i)) Then
Final.Add Current.Item(1), , i
Final.Add Current.Item(2), , , i
Current.Remove 1
Current.Remove 1
blnFound = True
Exit For
ElseIf Current.Item(1) = Final.Item(i) Then
blnFound = True
Next i
If blnFound = False Then
Current.Remove 1
Current.Remove 1
Loop
'Delete and re-add custom properties
swCustPropMgr.Delete vCustPropNames(i)
Next i
swCustPropMgr.Add2 Final.Item(i), swCustomInfoText, Final.Item(i + 1)
Next i
