9 Replies Latest reply on Oct 8, 2014 10:17 PM by Deepak Gupta
    RESTORE UP FROM MINIMIZED STATE
    James Kashuba
      is there a quick way to "restore up" all windows that have been minimized in SW? I am able to cycle through parts and drawings but the cycling does not necessarily restore them to maximized state. I hope this make sense to those reading.
      Jim
        • Re: RESTORE UP FROM MINIMIZED STATE
          Daniel Andersson
          Found something that might guide you. I just tried to record the macro and it worked. It gave my this... The code works for one open document.
          I have tried to make it apply for all open documents but I fail. When I loop I get different behavior depending on selected document.... not found why yet.
          Below is the macro that is failing, someone might find out why before I do (about to sleep...).
          To minimize:
          Dim swApp As Object
          Dim Part As Object
          Dim boolstatus As Boolean
          Set Part = swApp.ActiveDoc
          Dim myModelView As Object
          Set myModelView = Part.ActiveView
          myModelView.FrameLeft = 0
          myModelView.FrameTop = 0
          myModelView.FrameState = swWindowState_e.swWindowMinimized
          To Maximize:
          Dim swApp As Object
          Dim Part As Object
          myModelView.FrameState = swWindowState_e.swWindowMaximized
          Macro with different behavior depending on which minimized document is selected once macro is executed.
          Dim myModelView As SldWorks.ModelView
          Dim longwarnings As Long
          Dim strPath As String
          Set swModel = swApp.GetFirstDocument
          While Not swModel Is Nothing
              Set myModelView = swModel.ActiveView
              myModelView.FrameState = swWindowState_e.swWindowNormal
              Set swModel = swModel.GetNext
              If Not swModel Is Nothing Then
                  strPath = GetFilename(swModel.GetPathName)
                  swApp.ActivateDoc3 strPath, False, 2, longwarnings
          Wend
          Function GetFilename(ByVal strPath As String) As String
              If Right$(strPath, 1) <> "\" And Len(strPath) > 0 Then
                  GetFilename = GetFilename(Left$(strPath, Len(strPath) - 1)) + Right$(strPath, 1)
          End Function
          I might have a new try on the weekend....
          // Daniel
            Deepak Gupta
            Try if this one works:
            Dim vModels As Variant
            Dim index As Long
            Dim Errors As Long
            vModels = swApp.GetDocuments
            For index = LBound(vModels) To UBound(vModels)
                Set swModel = vModels(index)
                swApp.ActivateDoc3 swModel.GetPathName, False, 1, Errors
            Next index
                James Kashuba
                Deepak,
                Thanks for your input, you always seem to have an answer for me. Your code had an odd execution also. It maximized one assembly drawing and then it opened every part file associated with the that drawing while leaving all the other drawings minimized. The right function should only maximize what is minimized and not open anything. It is interesting to see two different approaches to the same problem (You and Daniel that is). Thanks for your time!
                    Daniel Seaman
                    Deepak's macro needs to check the visibility of each file opened:
                        If swModel.Visible <> False Then
                            myModelView.FrameState = swWindowState_e.swWindowMaximized ' or swWindowNormal if preferred.
                    Next index
                        James Kashuba
                        You nailed it Daniel! Thank you so much. It was Deepak's code with your tweek that worked. However, it didn't work at first. It seems that SW didn't like swWindowMaximized state. When I replaced that with swWindowNormal it functioned as intended.
                        I can't even begin to tell you All how much this helped me, THANK YOU.
                          Daniel Andersson
                          Edit: Ah, I see that you wrote at the same time as me. Glad that you find it working as you wanted.
                          The thing is that only one document can be maximized. Using macros above still minimizes if the user presses "Restore".
                          I think that James Kashuba is aiming to have all other windows Normal and one as Maximized. Then the behavior is as at least as I expect it... I have adjusted the macros from the input from Deepak Gupta and from Daniel Seaman.
                          James Kashuba, please let us know what behavior you expect from your end.
                          Dim sCurrentModel As String
                          Dim index As Long
                          Dim Errors As Long
                          Set swModel = swApp.ActiveDoc
                          sCurrentModel = swModel.GetPathName
                          Next index
                          swApp.ActivateDoc3 sCurrentModel, False, 1, Errors
                          // Daniel
                              James Kashuba
                              Daniel,
                              That is what I intended. Daniel Seaman's code worked as well, but there are differences between yours ans his. I played with a couple of scenarios, one of them being to have all open docs tiled vertical, then minimized and then restored. It worked as intended. However, when I tiled all docs and then restored them to maximized before minimizing; and then minimized them to restored them to tiled, it was not what I intended.  It still maximized all docs so I'm content with that, even if they were tiled. Your code on the other hand restored to what I had in mind. In the end, both do what I want. When I have time I am going to place your codes side by side to see the subtleties in your methods.
                              Thanks Daniel for you time!
                              Deepak Gupta
                              Thanks Daniel Seaman and Daniel Andersson for making me know as where I was making the mistake.
