I have a model of a 3D tube which is in .STP format. Now I want to create a axis for that tube, so that I can follow the same path to sweep with a different contour.
How can I do it? I tried to create the axis using reference axis command, but it didn't worked because the tube is a 3D tube, where as reference axis command works for only single plane!!!
Pls help.
hei'ya Yogesh,
maybe if you post your file,
using the advanced editor-top right of the reply pane
and attach button-bottom right of pane>browse to file,
members can see your problem and suggest their solutions
have a good'n kelef
