18 Replies Latest reply on Oct 28, 2014 3:43 PM by Matthew Lorono
    Where does SolidWorks get the hole callout from when using an extruded cut?
    Justin Hoidahl
      Where does the hole callout information come from when adding a callout to an extruded cut? I have modified the calloutformat.txt file to change the hole wizard standards but if I use the hole callout on a hole created with an extruded cut it doesn't seem to come from the .txt file. <MOD-DIAM><DIM> THRU is what comes in and it is not in the calloutformat.txt anywhere.
