I am running a custom system
with opteron 180
4 gigs of ram
quadra 3450 graphic card
and 3 250 gig drives in a raid 5 config
how can i be running out of ram and crashing?
with opteron 180
4 gigs of ram
How much memory does the system say it is using when you crash out?
Regards,
Thanks for the help.
If you are using 64Bit XP + 64Bit SolidWorks, it should not crash due to RAM issue, I tried render a assembly with 64Bit system, the machine only have 2GB RAM, but it can use up to 4GB virtual memory without crash and finish the rendering,
thanks again
You had wasted 1GB RAM, brother!
due to the 32bit architecture limitation, each application only allocate 2GB RAM, this figure can be increased to 3GB, if you enable the "3GB" switch.
To enable 3GB, you need to edit the boot.ini file as follow:
[boot loader]
timeout=5
default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /3GB /userva=2900 /fastdetect /noexecute=optin
But even you had enabled 3GB switch, SolidWorks still crash when it used 2.6~2.7GB RAM.
SO, the only solution for you is to convert your system into a 64bit XP!
Thanks for all your help
Below is what my boot file looks like...
So just cut, paste & save - reboot?
[boot loader]
timeout=30
default=multi(0)disk(0)rdisk(0)partition(1)WINDOWS
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)WINDOWS="Microsoft WindowsXP Professional" /noexecute=optin /fastdetect
Added the /sos switch as well.
Went right to an assembly that yesterday I could not render due tolack of resources.
It took about 6 mins, to render - but it worked!
to bad the sales department had to have those images for a quoteyesterday...
