Hi, I have done a FloWorks simulation where i have a thin
wall witha hot fluid on one side and a cold fluid on the other side
(air inboth cases). I have checked the 'heat conduction in solids'
checkbox in the general settings to allow heat conduction and i
havegiven boundary conditions to both sides of the wall
specifyingtheir roughness and heat transfer coefficient, i have
left 'definefluid temperature by' as 'user defined temperature' and
the'external fluid temperature' as 293.2 K. And then i ran
thesimulation. Now how do i view the heat transfer that has
takenplace by conjugate and conduction through the wall, so i can
seehow much heat has passed through the wall and where have been
thespots were the most has passed through? Also you may like to
knowthat it is an internal simulation and the wall and fluids on
bothsides are encapsulated in a larger box and are all apart of
thesimulation.
Thank you,
Duncan
Thank you,
Duncan
