Re: How to pattern Virtual parts?
Deepak Gupta Oct 1, 2014 3:34 AM (in response to Sanya Shmidt)For inserting multiple virtual components try these codes:
Option Explicit
Dim swPlaneFeature As SldWorks.Feature
Dim swPlane As SldWorks.RefPlane
Dim swAssem As SldWorks.AssemblyDoc
Dim i As Integer
Dim swVirtComp As SldWorks.Component2
Set swModel = swApp.ActiveDoc
If swModel.Extension.SelectByID2("Front Plane", "PLANE", 0, 0, 0, False, 0, Nothing, 0) = False Then
Debug.Print "Failed to select Front plane; check feature name."
Exit Sub
Set swPlaneFeature = swSelMgr.GetSelectedObject6(1, -1)
Set swPlane = swPlaneFeature.GetSpecificFeature2
Set swAssem = swModel
For i = 0 To 20
swAssem.InsertNewVirtualPart swPlane, swVirtComp
Next i
swAssem.ClearSelection2 True
Sanya Shmidt Oct 1, 2014 11:11 PM (in response to Deepak Gupta)Thank you Deepak for your respond.
The code above creates the first instance of the part with the correct name and the rest of them just Part^2, Part^3 etc...Is there any way to correct this?
Please see the video below.
https://dl.dropboxusercontent.com/u/23443066/VirtParts.avi
Thank you.
Deepak Gupta Oct 2, 2014 1:02 AM (in response to Sanya Shmidt)Try these following one:
Also would suggest to upload the attachments here instead of external sites.
Option Explicit
Dim i As Integer
Dim lResult As Long
Dim swSecondComp As SldWorks.Component2
Dim sVirtPart As String
Exit Sub
lResult = swAssem.InsertNewVirtualPart(swPlane, swVirtComp)
swVirtComp.Name2 = sVirtPart
If lResult = swInsertNewPartError_NoError Then
For i = 1 To 20
Set swSecondComp = swAssem.AddComponent5(swVirtComp.GetPathName, swAddComponentConfigOptions_CurrentSelectedConfig, "", False, "", 0.1, 0, 0)
Next i
Sanya Shmidt Oct 2, 2014 8:29 PM (in response to Deepak Gupta)Thank you.
Now it`s working great!
Do you know the answer to my 2nd question about assigning custom properties to a virtual part?
Alex.
Deepak Gupta Oct 3, 2014 1:36 PM (in response to Sanya Shmidt)Insert these codes:
Dim Part As Object
Dim Errors As Long
Set Part = swApp.ActivateDoc3(swVirtComp.GetPathName, False, 1, Errors)
Set Part = swApp.ActiveDoc
Part.CustomInfo2(Part.GetActiveConfiguration.Name, "Description") = "New VALUE" 'This is for updating an existing property.
swApp.CloseDoc Part.GetTitle
after
Sanya Shmidt Nov 20, 2014 9:00 AM (in response to Deepak Gupta)Finally I finished this code with the help of Bob Hanson. Thank you Bob.
Below is the working code, that checks if virtual part/pattern already exists, if it does it gets the qty and changes it to a new value. If it doesn`t exist it adds an instance and creates a linear pattern. Also it checks if the user typed 0(zero) in this case it deletes the virtual part.
Try
swAssem = CType(swModel, AssemblyDoc)
'checking for existence
Dim PatternFeature As Feature
PatternFeature = swAssem.FeatureByName(sVirtPart + "-Pattern")
Dim FeatureQty As Dimension 'weird ? qty is DIM?
Dim reVal As Integer
If Not PatternFeature Is Nothing Then
' checking if we need to delete the part
If vp_qty = 0 Then
If swModel.Extension.SelectByID2(sVirtPart + "^" + swModel.GetTitle + "-1@" + swModel.GetTitle, "COMPONENT", 0, 0, 0, False, 0, Nothing, 0) = False Then
Debug.Print("Failed to select part ; check feature name.")
Exit Sub
' deleting the part
swModel.Extension.DeleteSelection2(swDeleteSelectionOptions_e.swDelete_Children)
swModel.ForceRebuild3(False)
Exit Sub
FeatureQty = swModel.Parameter("D1@" + sVirtPart + "-Pattern")
reVal = FeatureQty.SetSystemValue3(vp_qty, swSetValueInConfiguration_e.swSetValue_InAllConfigurations, Nothing)
Exit Sub
' choosing the plane to drop Virtual part on
Debug.Print("Failed to select Front plane; check feature name.")
Exit Sub
' Assigning the name sVirtPart - is the part that User pick from Listbox 'sVirtPart = PartNumber(lbox_VParts.SelectedIndex) 'Dim swVirtComp As SldWorks.Component2 defined somewhere else
Dim mDoc As ModelDoc2
Dim custPropManager As CustomPropertyManager
mDoc = swVirtComp.GetModelDoc2
' adding and overwrting Custom properties
custPropManager = mDoc.Extension.CustomPropertyManager("Default")
custPropManager.Add3("Description", swCustomInfoType_e.swCustomInfoText, txt_NewPartDescr.Text, swCustomPropertyAddOption_e.swCustomPropertyReplaceValue)
custPropManager.Add3("Vendor", swCustomInfoType_e.swCustomInfoText, txt_Vendor.Text, swCustomPropertyAddOption_e.swCustomPropertyReplaceValue)
custPropManager.Add3("VendorNo", swCustomInfoType_e.swCustomInfoText, txt_VendorPN.Text, swCustomPropertyAddOption_e.swCustomPropertyReplaceValue)
' to be able to pattern the part we need to select it and select the axis
boolstatus = swModel.Extension.SelectByID2(swVirtComp.Name2 & "@" & swModel.GetTitle, "COMPONENT", 0, 0, 0, False, 1, Nothing, 0)
boolstatus = swModel.Extension.SelectByID2("X-Axis", "AXIS", 0, 0, 0, True, 2, Nothing, 0)
' creating the pattern
Dim FeatManager As FeatureManager
FeatManager = swModel.FeatureManager
FeatManager.FeatureLinearPattern(vp_qty, 1, 0, 0, False, False, "Qty", "")
' this portion of the code Getting the lase Pattern Feature and Renaming it to Match last Added Virtual part name.
Dim CurrentFeature As Feature
Dim PreviousFeature As Feature
CurrentFeature = swModel.FirstFeature
' cycling through the features and getting the last one
While Not CurrentFeature Is Nothing
PreviousFeature = CurrentFeature
CurrentFeature = CurrentFeature.GetNextFeature
End While
' renaming the pattern feature
PreviousFeature.Name = sVirtPart + "-Pattern"
mDoc.Save()
Catch ex As Exception
swApp.SendMsgToUser("An exception occurred:" & vbCrLf & ex.Message)
End Try
