I'm trying to modify an assembly, and for some reason my red wire is too long. It was originally a straight revolved wire, then I started a 3D sketch, tacked on a couple of stubs and a spline, then swept all of that into a wire. I did the same with the other three, but the red wire is trouble.
It would be hard to say anything without the file but you can check if there are any configuration in the red wire OR in the assembly? If yes then check if those are set up properly.
