2 Replies Latest reply on Sep 30, 2014 2:57 PM by Ricardo Martinez
    Open part from assembly, what i am doing wrong?
    Ricardo Martinez
      Hey fellas, I am beginning with the SW API. My name is Richard. I've been programming a macro to help me to rename assemblies and each part from they. Everything was well until I opened a part (.sldprt) from the assembly. It works (the document opens) but there is an error message that says: "Object doesnt support this property or method".
      This message only appears when I use "Part.OpenCompFile" to open a part (*.sldprt) I dont have any problem with the assemblies (*.sldasm). On the other hand, I've tried to use the "opendoc6" but it does not work.
      The code is the following... what am I doing wrong? Thanks!
      Excuse me if there are some incongruities on the code. In red and blue some notes about my problem.
      Private ruta                    As String
          Private name                    As String
          Private title                   As String
          Private names(5)                As String
          Private x                       As Integer
          Private ASM1                    As Integer
          Private ASM2                    As Integer
          Sub TraverseComponent(swComp As SldWorks.Component2, nLevel As Long)
          Dim swModel                     As SldWorks.ModelDoc2
          Dim vChildComp                  As Variant
          Dim swChildComp                 As SldWorks.Component2
          Dim sPadStr                     As String
          Dim i                           As Long
          vChildComp = swComp.GetChildren
          Debug.Print UBound(vChildComp) 'Presenta el numero de componentes determinado por vChildComp
          Set swModel = swApp.ActiveDoc
          For i = 0 To UBound(vChildComp)
              Set swChildComp = vChildComp(i)
              title = swModel.GetTitle ' Inicio A continuacion se adquiere el nombre del ensamble y se edita la extension del archivo
              title = Replace(title, ".sldasm", "") ' Inicio A continuacion se adquiere el nombre del ensamble y se edita la extension del archivo
              title = Replace(title, ".SLDASM", "") ' Inicio A continuacion se adquiere el nombre del ensamble y se edita la extension del archivo
              names(x) = swChildComp.Name2
              If x < 5 Then
                  names(x) = Replace(names(x), names(x + 1), "")
                  names(x) = Replace(names(x), "/", "")
                  name = (names(x) & "@" & title)
                  Debug.Print "Nombre: " & name
                  Else
              ruta = swChildComp.GetPathName
              ASM1 = InStr(ruta, ".sldasm")
              ASM2 = InStr(ruta, ".SLDASM")
              Debug.Print "Ruta: " & ruta
              If ASM1 Or ASM2 <> 0 Then
                  x = x - 1
              rename
              TraverseComponent swChildComp, nLevel + 1 ' PERMITE BUSCAR DENTRO DE OTRO ENSAMBLAJE
          Next i
          Sub rename()
          Dim swApp As Object
          Dim Part As Object
          Dim boolstatus As Boolean
          Set Part = swApp.ActiveDoc
          boolstatus = Part.Extension.SelectByID2(name, "COMPONENT", 0, 0, 0, False, 0, Nothing, 0)
          If ASM1 Or ASM2 = 0 Then
              'Part.OpenCompFile         ' This is for *.sldprt. Here the part (*.sldprt) opens but the error appears!
              Set Part = swApp.OpenDoc6(ruta, swDocPART, 0, "", longstatus, longwarnings) ' Tried to open the *.sldprt with opendoc6, does not work... why?
              Else
              Part.OpenCompFile          ' This is for *.sldasm, no problem.
          'swApp.CloseDoc "Cuerpo"
          Dim swApp                       As SldWorks.SldWorks
          Dim swConfMgr                   As SldWorks.ConfigurationManager
          Dim swConf                      As SldWorks.Configuration
          Dim swRootComp                  As SldWorks.Component2
          Set swConfMgr = swModel.ConfigurationManager
          Set swConf = swConfMgr.ActiveConfiguration
          Set swRootComp = swConf.GetRootComponent3(True)
          x = 5
          TraverseComponent swRootComp, 1
