Is there a way to import a .pdf file and convert the lines to a sketch? I was thinking i had seen this before but did not find it when i searched.
thanks
thanks
Thanks for all the responses, i realized the auto trace was on a .jpg not a .pdf was my confusion. i was able to make it work but it had a fair amount of extra lines or lines that did not follow
I tried Able2Extract and it converted some of the lines but not all. It may be because its a logo and some of it ended up hatched. Inkscape converted everything as i needed it done.
thanks again, all good methods i think depending on what you are doing
Firstly save PDF file as JPG, then use "sketch picture" & "auto trace", if the resolution is high enough, you can get the sketch.
