SW 2014 x64 SP3.0
I have scanned lots, and I mean lots, of forum posts and google results and keep coming across the advice to "open the routeAssembly.asmdot template and change the settings as required" but I have yet to see any instruction on how to do it. The file is not recognised when I double-click it in Windows Explorer and Solidworks does not recognise it through File / Open.
We are creating successful routes in our assemblies using the default standard imperial tubing, but are experiencing a few issues that we think can be solved by editing the template: tubing colour; tubing material; metric dimensions. We only use four different sizes of airline tube and they are all the same material and colour.
Any simple instructions on opening template files would be appreciated, thanks. (We think we are OK with file locations and part configurations, though by no means proficient !)
Routing uses the same ASMDOT file extension as a regular SolidWorks template.
So you can open and edit it in the usual fashion-by going to File==>Open and in the Open dialog box, changing the file type to document templata
This will automatically change the path to the first location in your templates search path (Options Dialog: System Options: File Locations)
The routing assembly tempalte will be called routeassembly.asmdot.
If it's not present in the default template location, try browsing to c:\programdata\SolidWorks\<SolidWorks Version>\templates\
