Hi
I am trying to create a cylinder with a simple extruded spike pattern on the outer surface of the cylinder.
Ive been trying to do this with the sheet metal tool, creating the extruded pattern on the unfolded cylinder. However when i fold the cylinder back up it does not keep any of the extruded spike i have made.
Not sure how else i can complete this.
Any suggestions would be greatly appreciated!
You should move/add the features above flat pattern feature. Anything below that will only appear when flat pattern is unsuppressed.
Any specific reason you doing it in sheet metal and not on simple cylinder? You can extrude one spike and then use linear/circular pattern to create the others.
