4 Replies Latest reply on Nov 17, 2014 7:31 AM by Masoud Hezari
    Problem with project Name in EPDM
    Masoud Hezari
      Hi
      i go to EPDM folder and generate new Project
      when go to construction of this project and want to build new Part or Assambly
      Name of them is not the same as project
      for example my project name is 1580-**** but when I try to create new part or assamply
      their Number begin 1508-A0001
      or 1508-P0001
      I do not understant what's the reason.
      Also If i renamed them to correct name and want to put some assmbly inside Assambly
      Error Note:(you can't put templete inside templete )
      Please if some body knows the reason help me.
      Thanks Masoud
        • Re: Problem with project Name in EPDM
          James Guilford
          Are you using a template to create the new part? if yes, are you using the serial generator as %variablename% as the part number?
              Masoud Hezari
              to answer your question yes I use EPDM to create new part and Assembles and in EPDM all have their own templetes
              serial generator is running by EPDM it means when you go to folder of new project and -new -part
              then it generate automaticly Document No....it is include :  Project No and part or Assembly No.
              problem is the generated no. is not correct
              it's not coming from project no .
              I have folder include project 1508 and my new project 580
              parts and assembly No.is not follow project No ..instead of 1580-A0001
              it is 1509-A0001
              I don't know why??
              can you help
              Now I go to another folder (in other path) and make project the No. become correct then completly copy  all project folders and parts after finishing to correct path
                  James Guilford
                  Hi Masoud,
                  I'm not sure if I fully understand what you are trying to do. However,there are different ways of doing this, for example, you can have the user to select the project in the template form and have that mapped to the name of the part. For example, if the user selects project 1508 then the part number would be %projectnumber%- serialgenerator
                  I hope that helps.
                  Cheers.
                  James
                      Masoud Hezari
                      Hi James,
                      thanks for you answer.
                      But,I can solve the problem by just generate new project to other folder.
                      Now , I have another problem .please if you have any Idea just let me know.
                      We usulay use our prevoius project to begin new one becouse alot of items are the same or up to 70% like previous project.
                      First i try to use Pack and Go and Copy Tree.but both don't have same problem about linking copy file and flder to source project.
                      How can i omit this link.
                      I have problem about copy tree Tools and Pack and Go.It means when we use them for do not design whole SubAssy , Assy and Parts one more time from begining in new project .for example we have project 130045 and now want to copy all files to project 130092
                      unfortunately,in Data card project no after copy for all files are 130045 not 130092
                      But result of Tree copy have these faults
                      1-In new Project all files linked to previous project and you can see in their Data Card
                      2-New project No is not effected on files and you see project No. belong to previous project
                      Do you have any solution for me?
                      Best wishes
                      Masoud
