Hi to all,
if after used the 'Penetrate' command, I notice that it's better to put a 'T' fitting, how I remove the 'Penetrate' command and replace all in automatic mode ?
A 'Unpenetrate' command for example...
Alessandro
Alessandro
Alessandro
I need to create a manifold with little tube in the intersections among it, but i don't know how to create this tipe of routing in the SW 2008, this manifold will be 3" and i want the penetrate to be smaller, but i don't use the "T", because my assembly is too small and i have to save space and reduce costs.
??can you teach me to do it?
Merry correct...
Just edit your route, split your route segment.
-DD
