I can't open an igs file, how to open it? when I open it, in font page of solidworks bottom image shows.
or how can I repair it? (If it damaged.)
uhmmm,
well.....
http://home.pct.edu/~jmather/AU2008/ML205-1P%20Mather.pdf
The file was actually an assembly of parts (created in Pro/E) with some missing faces.
I combined into one part as I suspected you don't really need as an assembly.
It would be quicker to use the Customer Drawing to recreate the part yourself.
http://drawings.amphenolrf.com/arfa_customer_outline/C34-1021.pdf
SolidWorks must finish opening the file. It might take more than a couple minutes for a large file. How long have you waited?
Try STP format also if possible.
What is the filesize?
How many surfaces are in the file?
If the IGS was converted from a triangle or polygon based format (ie STL or 3d scan), you may have a huge file with a large number of surfaces. There is a limit in SolidWorks with the number of surfaces, about 15,000 or so for solids, slightly more for open surfaces.
