I am currently running the latest version of Solidworks 2014 (SP.4), the problem I am having is my active window minimizes when I use the Replace Component command with an assembly file. It works fine if I just replace a part file but for some reason the assembly files cause my window to minimize every time. I also have the Re-attached mates option selected under options when this happens. Thanks for any advice/help
The same thing happens to me. I don't know anything to do about it, just wanted to let you know it's not just you.
