Need to know if this is possible - see attached
Want to create a weld between the gaps, I'm Currently running SW2014
Im trying to create a sheet metal tube with an endcap on it. to draw the tube i followed the tutorial found on youtube: Rolled Sheet Metal - SOLIDWORKS 2014 - YouTube
It can also be generated as a multi body part. That means you actually model the weld in the sheetmetal part. When you create the extrude simply uncheck the merge result check box. Your rolled sheetmetal part will still flatten but the weld will be suppressed.
