The 3 rectangles in the profile tend to not extrude with the rest of the profile. I think that may be causing my problem. The sketch extrudes just fine so long as its done via choosing contours. It says Invalid member profile, check your library.
I even added a point to pierce, and still no dice. Im out of ideas.
Thanks for your help guys!
do you want to know why?
you have 2 cases of double lines in your sketch (there are 4 lines inside of the red line):
also it is a good idea to always fully define your sketches.
