7 Replies Latest reply on May 30, 2016 9:45 AM by Danilo Martins
    Differences between write code in VBA editor and in the properties
    Danilo Martins
      Hello there,
      I'm trying to get a simple macro to run under the properties of the file. As example i'll use a macro to calculate the volume of a part in dm³. As i'm using SolidWorks 2012, I don't have the unit cubic decimeters.
      That's the simpler code that works for me:
      Dim Part As Object
      Dim boolstatus As Boolean
      Dim mass As SldWorks.MassProperty
      Dim retval As String
      Dim Volume As String
              Set Part = swApp.ActiveDoc
              Set mass = Part.Extension.CreateMassProperty
              boolstatus = mass.AddBodies((compbody))
              mass.UseSystemUnits = False
              Volume = mass.Volume / 1000000
              Part.DeleteCustomInfo ("VOLUME dm3")
              Part.AddCustomInfo3 "", "VOLUME dm3", swCustomInfoText, FormatNumber(Volume, 3, vbUseDefault, vbUseDefault, vbUseDefault)
      All I want is to put the code under the properties of a part, and call it using Equations. I know that I can't do some things calling the macro under properties, but what is wrong? Can anyone explain more about this differences?
      Thanks a lot! I hope this informations opens my world!
        • Re: Differences between write code in VBA editor and in the properties
          Danilo Martins
          Just to explain, if my question doesn't make sense for everybody, I wan't to put the code in the properties because I don't wan't to run the macro manually. I need that in every Ctrl+Q or rebuild the volume get updated.
              Drew Adams
              I think it sounds like you need an "add-in" and not a macro.  An Add-in can run constantly in the background, but the macro would have to be called to run on its own each time.  You could customize the toolbar/keyboard to create a hotkey to run the macro though, which is what I would recommend should you decide not to go the Add-in route.
              Hope that helps.
              -Drew
                Jim Sculley
                Use a macro feature to run macro code on every rebuild.  Search the API Help for 'macro feature' for details and examples.
                Jim S.
                    Danilo Martins
                    Well, it seems to do what I want.
                    How to create this macro feature?
                        Daniel Andersson
                        You could run the macro on event, rebuild. See the bottom of this page for all events that can be used in SolidWorks.
                        To use events with macros you have to launch the macro at some point. Once launched it will stay in background and respond to the events you trigger.
                        The macro can be launched at the same time as SolidWorks by making a new shortcut. See this post with macro example for events and for how to add a SolidWorks shortcut that launches a macro on start up.
                        Using events will implement this to ALL files that is being opened and rebuilt. IF statements and/or select case could be used to get some filtering done depending on filename or custom properties etc.
                        If you want just for specifc documents from time to time, then you should go for adding a macro icon and add a shortcut to it. It may be possible to change the ctrl+q to run the macro instead. A minor tweak of the macro is then needed, so that the document also rebuilt when the macro is executed.
                        The option with add-in is something to consider if you have multiple users and is even more relevant if the actions should be event based.
                        Please let me know if you need any further assistance.
                        // Daniel
                            Daniel Andersson
                            I had a second thought about this and changed my mind.
                            I think the best would be to have a macro that adds a equation and a custom property that is linked to the equation. Once done you do not have to think of rebuilds etc.
                            If you like I could help you to set up a macro like that.
                                Danilo Martins
                                Daniel, 2 years from there and again I'm in trouble.
                                I created a macro an saved it in the part file, so a equation calls it on every rebuild.
                                But thats my new problem, since it calls my macro on every rebuild, it remains opened! When I try to edit a macro I see a lot of instances of the macro that the equation calls opened, and consuming all my memory.
                                Below my current macro. Any help?
                                Option Explicit
                                    Dim swModel             As SldWorks.ModelDoc2
                                    Dim swConfigMgr         As SldWorks.ConfigurationManager
                                    Dim swConfig            As SldWorks.Configuration
                                    Dim swCustPropMgr       As SldWorks.CustomPropertyManager
                                    Dim valOut              As String
                                    Dim TIPO      As String
                                    Dim retval As Boolean
                                    Dim ALTURA As Variant
                                    Dim LARGURA As Variant
                                    Dim COMPRIMENTO As Variant
                                    Dim MEDIDA1 As Variant
                                    Dim MEDIDA2 As Variant
                                    Dim MEDIDA3 As Variant
                                    Dim DIAMETRO As Variant
                                    Dim CANTOS As Variant
                                    Set swModel = swApp.ActiveDoc
                                    Set swConfigMgr = swModel.ConfigurationManager
                                    Set swConfig = swConfigMgr.ActiveConfiguration
                                    'Debug.Print "Name of this configuration:" & swConfig.Name
                                    Set swCustPropMgr = swConfig.CustomPropertyManager
                                    swCustPropMgr.Get2 "TIPO", valOut, TIPO
                                    'MsgBox TIPO
                                If TIPO = "MANUAL" Or TIPO = "PERFIL" Then 'ENCERRAR PREENCHIMENTO AUTOMÁTICO
                                    End
                                If TIPO <> "TRABALHADO" And TIPO <> "CHAPA" And TIPO <> "EIXO" And TIPO <> "BRUTO" And TIPO <> "TORNEADO" And TIPO <> "BARRA QUADRADA" And TIPO <> "BARRA REDONDA" Then
                                    MsgBox "Tipo de fabricação não conhecido." + vbCrLf + _
                                            "Preencha o TIPO como uma das opções:" + vbCrLf + _
                                            "TRABALHADO, TORNEADO, CHAPA, EIXO, BRUTO, BARRA QUADRADA ou BARRA REDONDA" + vbCrLf + vbCrLf + _
                                            "Ou preecha com MANUAL para escrever manualmente conforme necessário"
                                    End
                                'MsgBox TIPO
                                'LER MEDIDAS
                                CANTOS = swModel.GetPartBox(True)         'True comes back as system units - meters
                                ALTURA = Round((Abs(CANTOS(4) - CANTOS(1)) * 1000), 2) ' Z axis
                                LARGURA = Round((Abs(CANTOS(5) - CANTOS(2)) * 1000), 2)  ' Y axis
                                COMPRIMENTO = Round((Abs(CANTOS(3) - CANTOS(0)) * 1000), 2) ' X axis
                                'ORDENAR AS DIMENSOES
                                If ALTURA > LARGURA Then
                                    If ALTURA > COMPRIMENTO Then
                                        MEDIDA1 = ALTURA
                                        If LARGURA > COMPRIMENTO Then
                                        MEDIDA2 = LARGURA
                                        MEDIDA3 = COMPRIMENTO
                                        Else
                                        MEDIDA2 = COMPRIMENTO
                                        MEDIDA3 = LARGURA
                                    Else
                                        MEDIDA1 = COMPRIMENTO
                                        MEDIDA2 = ALTURA
                                        MEDIDA3 = LARGURA
                                Else
                                    If COMPRIMENTO > LARGURA Then
                                        MEDIDA2 = LARGURA
                                        MEDIDA3 = ALTURA
                                    Else
                                        MEDIDA1 = LARGURA
                                        MEDIDA2 = ALTURA
                                'MsgBox MEDIDA1 & " x " & MEDIDA2 & " x " & MEDIDA3 'MOSTRAR MEDIDAS
                                'If TIPO <> "MANUAL" Then
                                    swCustPropMgr.Delete "DIMENSIONAL"
                                'End If
                                'PREENCHER DE ACORDO COM TIPO
                                If TIPO = "TRABALHADO" Then
                                    retval = swCustPropMgr.Add2("DIMENSIONAL", swCustomInfoText, _
                                            "t. " & MEDIDA3 & " x " & MEDIDA2 & " x " & MEDIDA1)
                                ElseIf TIPO = "CHAPA" Then
                                             "ch. " & MEDIDA3 & " x " & MEDIDA2 & " x " & MEDIDA1)  'ESCREVER VALORES
                                ElseIf TIPO = "EIXO" Then
                                    If MEDIDA1 = MEDIDA2 Then
                                            DIAMETRO = MEDIDA1
                                            COMPRIMENTO = MEDIDA3
                                        ElseIf MEDIDA2 = MEDIDA3 Then
                                            DIAMETRO = MEDIDA2
                                            COMPRIMENTO = MEDIDA1
                                        ElseIf MEDIDA1 = MEDIDA3 Then
                                            DIAMETRO = MEDIDA3
                                            COMPRIMENTO = MEDIDA2
                                             "Ø" & DIAMETRO & " x " & COMPRIMENTO)  'ESCREVER VALORES
                                ElseIf TIPO = "BRUTO" Then
                                             "Br. " & MEDIDA3 & " x " & MEDIDA2 & " x " & MEDIDA1)  'ESCREVER VALORES
                                ElseIf TIPO = "BARRA QUADRADA" Then
                                             "barra " & MEDIDA3 & " x " & MEDIDA2 & " x " & MEDIDA1)  'ESCREVER VALORES
                                ElseIf TIPO = "BARRA REDONDA" Then
                                            DIAMETRO = MEDIDA1
                                            DIAMETRO = MEDIDA2
                                            DIAMETRO = MEDIDA3
                                             "barra Ø" & DIAMETRO & " x " & COMPRIMENTO)  'ESCREVER VALORES
                                ElseIf TIPO = "TORNEADO" Then
                                            DIAMETRO = MEDIDA1
                                            DIAMETRO = MEDIDA2
                                            DIAMETRO = MEDIDA3
                                             "t. Ø" & DIAMETRO & " x " & COMPRIMENTO)  'ESCREVER VALORES
                                Else
                                    'MsgBox "TIPO """ & TIPO & """ NÃO CADASTRADO PARA PREENCHIMENTO DO DIMENSIONAL AUTOMÁTICO."
