I have a large assembly with several pipe routes which are routed along a plane using the route along relation. I'm having a problem with the routes flipping their relations from one side of the plan to the other so that instead of the pipe running 5" below the plane it runs 5" above. When I correct the relation the route will stay as desired for several rebuilds and saves and then will seemingly randomly flip agian. Has anyone else experienced this and found a fix?
We had something similar happening early last year and before that.
What version, and what SP of it, are you using?
