Re: Keeping Current Prefix and Adding New One to Drawing Dimensions
Deepak Gupta Sep 24, 2014 1:25 PM (in response to Jay Wagamon)Jay does this macro works for you? I'm getting errors in using this macro.
if the macro works for you then try using "4 x " & CurPrefix & " "
Jay Wagamon Sep 24, 2014 1:59 PM (in response to Deepak Gupta)Deepak,
No this does not work for me either. I removed the System in Dim CurPrefix As System.String so it's now Dim CurPrefix As String and now it runs but it does not do anything to the dimension. When I run it in the editor without selecting the dimension it gives me a compile error: object required for CurPrefix. I did try it with "4 x " & CurPrefix & " " and that did not work either.
Here's the macro that I currently use that deletes the existing prefix and puts in "4 x".
Dim swApp As Object
Dim Part As Object
Dim boolstatus As Boolean
Set swApp = _
Application.SldWorks
Set Part = swApp.ActiveDoc
boolstatus = Part.EditDimensionProperties2(0, 0, 0, "", "", True, 9, 2, True, 12, 12, "4 x ", "", True, "", "", False)
Part.ClearSelection2 True
Jay
Jesse Seger Sep 24, 2014 2:45 PM (in response to Jay Wagamon)Here is the working code.
' This Macro will add 4 x in front of the dimension in a drawing
' and keep the original Dimension Prefix.
' Preconditions:
' 1. Open a drawing.
' 2. Select a dimension.
Dim selMgr As SelectionMgr
Dim swModelDocExt As SldWorks.ModelDocExtension
Dim swDispDim As SldWorks.DisplayDimension
Dim swDim As SldWorks.Dimension
Set swModel = swApp.ActiveDoc
Set selMgr = swModel.SelectionManager
Set swModelDocExt = swModel.Extension
Debug.Print selMgr.GetSelectedObjectType(1)
Set swDispDim = selMgr.GetSelectedObject6(1, 0)
CurPrefix = swDispDim.GetText(swDimensionTextParts_e.swDimensionTextPrefix)
Set swDim = swDispDim.GetDimension
boolstatus = swModelDocExt.EditDimensionProperties(0, 0, 0, "", "", True, 9, 2, True, 12, 12, "4 x " & CurPrefix, "", True, "", "", False, False, 0, "")
swModel.ClearSelection2 True
Jay Wagamon Sep 24, 2014 3:10 PM (in response to Jesse Seger)Jesse that works perfectly! Thanks this is going to save me a bunch of time on prints!
Thanks guys for the help!!!
Jay
Jay Wagamon Sep 25, 2014 3:30 PM (in response to Jay Wagamon)Roger,
It does change the precision to the document precision which is the one thing i don't like. Most of the time I am making a new print so I like to do the multiplier first and then change the precision after if it's different from the document precision. Then a style does do the same thing but i like to use a hot key to run my macro so i can use my mouse to dimension and before going to my next dimension hit my hot key to get my multiplier. This seems to be faster to me but its all preference.
Deepak Gupta Sep 26, 2014 7:25 AM (in response to Jay Wagamon)Use this line in case you want to retain the dimension precision
boolstatus = swModelDocExt.EditDimensionProperties(0, 0, 0, "", "", False, 9, 2, True, 12, 12, "4 x " & CurPrefix, "", True, "", "", False, False, 0, "")
Also when I used the macro, it would put a False under the dimension if you not noticed. So I removed this False and changed to ""
boolstatus = swModelDocExt.EditDimensionProperties(0, 0, 0, "", "", False, 9, 2, True, 12, 12, "4 x " & CurPrefix, "", True, "", "", "", False, 0, "")
Jay Wagamon Sep 26, 2014 8:30 AM (in response to Jay Wagamon)Thanks Deepak that works beautifully! I also ended up removing the false statement after one of my coworkers had the problem with False under his dimension. I don't exactly know why it didn't say false when I used the macro but now its just how I want it. Thanks for the help Deepak!
This is the new full macro
' This Macro will add Quantity x in front of the dimension in a drawing
' Preconditions:
Lois Claracq Feb 3, 2015 2:11 PM (in response to Jay Wagamon)If you only want to change text you should use "SetText". It does not change any property of the dimensions
Here is an example which basically loop every selected dimension and add a suffix and text below :
For i = 1 To swSelMgr.GetSelectedObjectCount2(0)
Set swDispDim = swSelMgr.GetSelectedObject6(i, 0)
swDispDim.SetText swDimensionTextParts_e.swDimensionTextSuffix, " suffix"
swDispDim.SetText swDimensionTextParts_e.swDimensionTextCalloutBelow, "text below dim"
Next
swModel.GraphicsRedraw2
