I am trying to create a macro to insert a note (which is linked to a custom model property) on a batch basis. I also need to create one to delete the same note on a batch basis. I've recorded a macro to insert the note, but I have failed to splice it into a macro Deepak created. I consistently have the need to splice a recorded macro into a batch macro, but succeed only half the time.
Can anyone help me understand what mistakes I've made in the following?
Here is my recorded macro:
' C:\Users\t6\AppData\Local\Temp\swx14600\Macro1.swb - macro recorded on 09/24/14 by T6
Dim swApp As Object
Dim Part As Object
Dim boolstatus As Boolean
Set swApp = _
Application.SldWorks
Set Part = swApp.ActiveDoc
Dim myNote As Object
Dim myAnnotation As Object
Dim myTextFormat As Object
Set myNote = Part.InsertNote("$PRPSHEET:""Actual OD""")
If Not myNote Is Nothing Then
myNote.Angle = 0
boolstatus = myNote.SetBalloon(0, 0)
Set myAnnotation = myNote.GetAnnotation()
If Not myAnnotation Is Nothing Then
longstatus = myAnnotation.SetLeader3(swLeaderStyle_e.swNO_LEADER, 0, True, False, False, False)
boolstatus = myAnnotation.SetPosition(0.04737609567901, 0.1793169444444, 0)
boolstatus = myAnnotation.SetTextFormat(0, True, myTextFormat)
Part.ClearSelection2 True
Part.WindowRedraw
_____________________
and here is my splice job:
' Batch File Open and Save (Update Document Properties)------------------------------08/24/12
' Browse Folder codes: http://www.vbaexpress.com/kb/getarticle.php?kb_id=246
' Macro edited as per requirements from Aaron Felsing on SolidWorks forums: https://forum.solidworks.com/message/310724#310724
' Macro will find all the drawing files in the specified Path/location,
' update the specified Document Properties & save them in the same Path/location.
' This macro is provided as is. No claims, support, refund, safety net, or
' warranties are expressed or implied. By using this macro and/or its code in
' any way whatsoever, the user and any entities which the user represents,
' agree to hold the authors free of any and all liability. Free distribution
' and use of this code in other free works is welcome. If any portion of
' this code is used in other works, credit to the authors must be placed in
' that work within a user viewable location (e.g., macro header). All other
' forms of distribution (i.e., not free, fee for delivery, etc) are prohibited
' without the expressed written consent by the authors. Use at your own risk!
' Written by: Deepak Gupta (http://gupta9665.wordpress.com/)
Option Explicit
Dim swModel As ModelDoc2
Dim sFileName As String, Path As String
'Dim Part As swModel
Path = BrowseFolder("Select a Path/Folder")
Path = Path + "C:\\\\"
sFileName = Dir(Path & "*.slddrw")
Do Until sFileName = ""
'Set swModel = swApp.OpenDoc6(Path + sFileName, swDocDRAWING, swOpenDocOptions_Silent, "", longstatus, longwarnings)
Set myNote = swModel.InsertNote("$PRPSHEET:""Actual OD""")
myNote.Angle = 0
swModel.ForceRebuild3 (False)
swModel.Save
swApp.CloseDoc swModel.GetTitle
Set swModel = Nothing
sFileName = Dir
Loop
If anyone has any direction, I appreciate it. Also, I regularly run into this-- can anyone speak to the modularity of Macros? Are there any examples of a collection of batch macros, with a "do" section in the middle where recorded sections can be spliced in? Thank you!
