AMArne Morten Fredriksen24/09/2014
I'm trying to create an ePDM addin that handles rebuilding, and reopening of a drawing inside SolidWorks.
The code is executed at the EdmCmd_PostState event in ePDM. After the code has executed the drawing has change state, it has been rebuilded and everything looks alright. But, an error message is thrown every time and the ePDM task pane inside SolidWorks is not updated.
The error message says:
Could not Change the State of the file.
Error=0x80010108
Description='The object invoked has disconnected from its clients.'
I have commented the part of the code who is responsible for the error to appear.
Here is the stripped down code:
Case EdmCmdType.EdmCmd_PostState
     'Get file and folder object.
     Dim oFile As EdmLib.IEdmFile7 = oVault.GetObject(EdmLib.EdmObjectType.EdmObject_File, ppoData(nIndex).mlObjectID1)
     Dim oFolder As EdmLib.IEdmFolder6 = oVault.GetObject(EdmLib.EdmObjectType.EdmObject_Folder, ppoData(nIndex).mlObjectID2)
     'Full file path.
     Dim sFullFilePath As String = "C:\TestVault\CAD\Part1.slddrw"
     'Get latest version of the file.
     oFile.GetFileCopy(0, 0)
     'Check the file out.
     oFile.LockFile(oFolder.ID, 0)
     'Connect to SolidWorks.
     Dim oSolidWorksApplication As Object = Nothing
     oSolidWorksApplication = GetObject(, "SldWorks.Application")
     'Activate the drawing document in SolidWorks.
     Dim nError As Integer
     Dim oDocument As SldWorks.ModelDoc2
     oDocument = oSolidWorksApplication.ActivateDoc2(sFullFilePath, True, nError)
     'Rebuild drawing.
     oDocument.Rebuild(SwConst.swRebuildOptions_e.swForceRebuildAll)
     'Save the rebuilded drawing.
     oDocument.Save2(True)
     'Reopen the document in SolidWorks.
     Dim nOption As System.Int32 = 0
     Dim nValue As System.Int32
     Dim oNewDoc As SldWorks.ModelDoc2 = Nothing
     '----THIS IS THE LINE OF CODE WHO TRIGGERS THE ERROR MESSAGE----
     nValue = DirectCast(oSolidWorksApplication, SldWorks.SldWorks).CloseAndReopen(oDocument, nOption, oNewDoc) 'The return value nValue is 0 meaning nothing went wrong.
     oDocument = Nothing
     oNewDoc = Nothing
     'Check in the document.
     oFile.UnlockFile(0, "Saved Rebuilded drawing")
     System.Runtime.InteropServices.Marshal.FinalReleaseComObject(oSolidWorksApplication)
     oSolidWorksApplication = Nothing
     GC.Collect()
     GC.WaitForPendingFinalizers()
     GC.Collect()
Does anyone have a clue of what is happening here???
I have debugged this for 2 days now without any result.
Any help will be appreciated.
Thanks in advance.
