JKJeff Klare24/09/2014
When I start a new drawing, I pick our template which brings in the title block i want to use and has the revision block in the upper right corner. Then when I add a new sheet, the title block is completely different and the revision block is missing. I believe it has something to do with the .drwdot and .slddrt files in our library. How can i get the two files to be the same so when i add a new sheet, they both look the same? I thought i could open the .drwdot file and overwrite the .slddrt file, but, it does not allow that.
