I'm looking for a way to link a cell in an Excel document to a SW drawing dimension. Here's some background. I have an Excel document that I have inserted into a SW drawing. This document performs some engineering calculations which are based on the drawing dimensions. I would like to have the drawing dimensions drive specific cells in the Excel document so that the calculations automatically update when the drawing dimensions are changed.
I know that it is possible to do this using a SW General Table where you can simply double click on a cell and then select a dimension from the drawing. Unfortunately, doing complex engineering calculations with the SW General Table is very cumbersome. I would like to achieve a similar link, but with an Excel table in the drawing instead. I know this is possible within a Part Design Table, but my preference is to do this within a drawing because it is much easier to document the calculations with a drawing. I've been told this might be possible with a macro and SW API, but I have very limited programming experience. Any suggestions would be greatly appreciated. Thanks.
