I have a motor which oscillatates the green component along x-axis like an actuator. The green component should have a linear speed between 320mm/s and 330mm/s. I have to calculate which speed the motor must have in order to satisfy this requirement.
I have tried:
1. Rotate the motor from 0deg/s up to 2000deg/s in 10 seconds. And then create a linear velocity graf for the green part. The plot should give me a range in seconds where the speed is between 320 and 330mm/s. Having the time I can get the rotation speed of the motor from the function builder graphs in motors motion data(segmnets).
However this method is not very accurate. How can I get the green part to move exatly between 320 and 330mm/s? What other options do I have?
Hi Alex,
I have come up with the motor speed required to for the Slider to achieve a linear velocity 320-330 mm/sec. Please find the assembly in the attachement.
THere were some work around that I had to do as I am working on SW 2012 Premium; they are as described in the following:
1. As the 3D models were created in the higher version of SW, i had to import it using another CAD software in Step file format. So the parts when you refer will be defeatured.
2. SW2012 does not have spherical mates, like the newer version, hence I had to give a different mate criterion to manifest a Ball-Socket Joint. You will be able to refer it in the attached files.
If you are ok with these work-arounds then, I feel the motion analysis done, should be acceptable.
Anyways do let me know your thoughts on this.
Cheers!!
