Hello all,
I have two flat cut-out patterns imported from another CAD program. They imitate 6mm plywood panels. They have to be joined together by the edge, so that the corners meet, however, since these edges are curved, both parts have to bend into 3D shape to fit.
Attaching an image. Red line indicates which edges must be joined together. They are the same length.
Attaching the assembly also, in SW 2014.
What would be painless way to do this task? I have no idea which Feature or combination of features to use. It would be very easy to do with any flexible material in real life, but I have no idea how to fit these two parts in SW in this way.
You could try using the deform feature in edge-to-edge mode, but that rarely produces useable results.
In your situation, I would backtrack to the 3D data that the flattening program used to generate the blanks and import that into SolidWorks.
