All,
I'm looking for some input or use cases where you would want to not use the Minimum Twist option under Path alignment type in Sweep. Is there a case for actually wanting to leave the random twisting in a Sweep when not using the Twist Along Path or Twist Along Path With Normal Constant? Let's say we were able to fix the seemingly random twists that sometimes happen with sweep and no longer needed the Minimum Twist option since it would always have minimum twist. Would any of your designs be negatively impacted without the random twisting/kinking?
The images below show examples of Minimum Twist off and then on
As you can see, Minimum Twist removes the nasty kinking in the 3D Sweep.
Thanks for you help and insight.
Jody
Since as far as I know the twisting is unpredictable with minimum twist disabled, I don't see why anyone would want it off. If someone needs a twist that is not uniform then I imagine they would use a guide curve.
