I frequently need to offset three of the four sides of a part, so use the offset function. The default offset is 0.100." I always offset 0.75" and would like to set that as the default offset distance. I've looked, but have not been able to find the setting.
Is it possible to alter the default offset distance? If so, how is it done?
-Chris
Hi Chris,
you can change global settings:
system options/spin box increments - change length increment from default 0.10in to 0.75in.
but remember that will automatically change your global settings for all length increments.
regards,
Tomasz
