I have an assembly of a track that I am trying to drive with a design table. So when you open the design table and enter in a desired track length and it patterns the parts to create the desired length with the correct amount of parts. Its a pretty simple design table and it worked for a while. The problem that occurs is that for some reason now when using this design table things happen which are kind of bizarre.
The track design table works correctly if it makes one that is larger than what is on the screen. So changing a 4M track to a 40M track it populates correctly. The problem occurs when try and make a 20M track a 8M track. Only half of the patterns seem to update so the base weldments and rail lengths are correct, but the rail covers and splice kits are still patterned to the 20M length. When I open the design table all the numbers are correct but if I open the actual pattern the numbers are still left at the previous size.
If you have any ideas please let me know.
Adam
If you ctrl+q to rebuild does it fix it? How about if you change configurations and then change back?
